As the image shown below shows title, ref, submitted by. i wanted to know if it is possible to filter the columns by there column names...like is it possible to put a filter just to display all the titles and submitted by column.like out of 5 columns i want to filter to just display 2 columns.
      Hi, in the Datalist Builder you can remove the columns that you do not want to display. In the column properties, there is also an option to set it as Hidden.
        Hi, I would like to understand your thought process as to why would you like to do something like this. If it was me I will just create another datalist with just those 2 columns that you want and adjust the permission so that only the people you allow will be able to view it.
        1. saili bakalkar
          the requirements of my project demand a drop down from which one can select the columns to be displayed..... something like this.....
