Hello again Sarah,
You may refer to this page for more information on using the Route node: Process Builder
Basically, from what I understand about your question, I assume that you have 2 paths in your process that will flow in parallel, where one path will wait for the other path to complete before flowing again. (Correct me if i'm wrong)
In this case, you may use a Route node to have the 2 paths transition to it (2 paths joining to the Route). Then, configure the Route - Join Type as AND. This will do the trick
Hope this helps!
Is it possible to replace the "Waiting for Response" activity with a tool instead of an activity? https://dev.joget.org/community/display/KBv5/Multiple+Approval?preview=/12976907/13271162/apply.jpg Also, the subprocess is not linked with the main process.
