Joget DX Available for Download
Dear Expert,
I have 3 from in Application (attached .jwa)
1st form = Car data (CarID, Car Owner)
       Example
               BA 0001, AAAA
               BA 0002, BBBB
               BA 0003, CCCC
2nd form = Car Device data (Serial Number, CardID, Device Name)
              Serial1, BA 0001, Samsung Tablet
              Serial2, BA 0001, CAR TV
              Serial3, BA 0001, CAR RADIO
3rd form = Car Check List
 In 3rd form I have
        Multi select box  (JDBC Query to List Car Data from 1st form)
        AJAX Subform to show data from (1st Form)
My Question is How can I list all device in 2nd form, that belong to selected CarID from the selected box.
from example, I need the listed of all device name (Samsung Tablet, CAR TV, CAR RADIO) which is in Car BA 0001.
Attached are .jwa for this
APP_CarAsset-1-20181022175559.jwa
Please help
      Dear Justin, Thank for your answer, but I need all serial number from 2nd form, and return to main form or Workflow variable.
        Hey there,
        For your AJAX Subform, edit the properties, go to Data & Binder, under the Data Linkage tab, you can make use of this field, Parent Field to keep Subform ID. In this field, type in the form field ID of your multi-select box or any select box that contains the record ID for the subform to display the record data.
        Hope this helps!
