Hi, did you follow the steps in https://dev.joget.org/community/display/KBv6/Joget+Workflow+Open+Source? Especially the step to install 3rd party libraries.
ext { minSdkVersion = 14 compileSdkVersion = 19 targetSdkVersion = 19 buildToolsVersion = "19.1.0" }and this is my PARSELOGINUI'S build.gradle:apply plugin: 'com.android.library'dependencies { compile project(':facebook-sdk:facebook') compile 'com.android.support:support-v4:13.0.+' compile fileTree(dir: 'libs', include: '*.jar') }android { compileSdkVersion rootProject.ext.compileSdkVersion buildToolsVersion rootProject.ext.buildToolsVersion defaultConfig { minSdkVersion rootProject.ext.minSdkVersion targetSdkVersion rootProject.ext.targetSdkVersion } sourceSets { main { manifest.srcFile 'AndroidManifest.xml' java.srcDirs = ['src'] res.srcDirs = ['res'] } } productFlavors { } buildTypes { } }this seemed to work for me, don't know if there is a better solution out there. I like it because changing my main project's details will reflect the changes in the library as well. |
I'm having the same issue and have tried the method posted by @bestvibes with no luck.I'm using Android Studio 0.8.14 and am trying to import ParseLoginUI following these steps:
Error:(10, 0) Cannot get property 'compileSdkVersion' on extra properties extension as it does not existIn Android Studio it indicates that in the build.gradle there are a lot of unresolvable symbols.Any ideas? |
Ok, after looking through this repositories gradle settings and properties, I finally got the project imported.This is what I did:
Seems to be working so far. |
Sure ,I have resolved it by your comment,Thank you !!
