Hi Syed,
I assume that you local machine situation should be like this.
Can you check command of "joget-stop.bat" in each joget folder? Is it including database shutdown command which make DB server stop then joget could not start properly because DB server is no available.
Hi Auttakorn, i am working on MAC. Every time i try to start V5, i first stop V6. but stopping V6 does not cause database shutdown.
I recently changed my working machine. on that i have installed the Joget V6 and connected it to the local mysql server. MySQL version is 8.0.11. For V6 the db name is jwdb_v6. this part is working fine. I have to install V5 also. this version is pointing to the same mysql server but to different database i.e. jwdb_v5. but the problem is that some how joget is not able to connect to the server. On the setup screen this is the error:
i tried to put the the db connection string manually as well.
the above mentioned connection string works for V6 (jwdb_v6) but for somehow not working for V5.
And the logs only say this:
I event tried different sub versions of V5. but the problem is same. so i suspect that it can be because of mysql server. but i am not sure. So Please Help.
