Hey Faisal,
Perhaps you may try to reinstall/redeploy Joget Workflow again, or you may initialize the db 'jwdb'.
You may refer to this guide here: Installation on Linux
Hope this helps.
Hi Justin, Thanks for the advice, i already follow exactly the same as what guideline on how to install in linux. The error message is still the same. Here is detail os that i used; Distributor ID: Ubuntu Description: Ubuntu 18.04.1 LTS Release: 18.04 Codename: bionic Database: running on MariaDB. Any idea on this matter?
I need help after installation of JW v6, i could not see default app center and then try to create new app but i'm getting error failed to create table. I go through tomcat log i found that during the start of tomcat look like error to deploy default application from JW. here as follow is the logs;
INFO 24 Sep 2018 18:14:48 org.joget.commons.util.SetupManager - Initializing setup cache
INFO 24 Sep 2018 18:14:49 org.joget.plugin.base.PluginManager - PluginManager initialized
INFO 24 Sep 2018 18:15:11 org.joget.workflow.model.service.WorkflowManagerImpl - Datasource bound to jwdb
SharkEngineManager -> Shark engine is being initialized ...
Unknown JDBC Driver Vendor for : null using default (Standard) instead
Shark -> shark engine initialization is finished, it lasted 2 [s]
Shark -> SharkExampleJSP ready and waiting ...
2018-09-24 18:15:24,877: Import app /setup/apps/APP_crm-1.zip
2018-09-24 18:15:30,966: (conn:120) Table 'jwdb.app_fd_j_crm_account' doesn't exist
2018-09-24 18:15:35,307: Failed to import app /setup/apps/APP_crm-1.zip
org.joget.apps.app.model.ImportAppException: Failed to create form data table j_crm_account
The version that i used is: joget-enterprise-linux-6.0.11
I hope got someone get help me to resolve because i wanted to propose to my management about this JW.
