Thanks for that, unfortunately, I am not a web developer as such and it seems a bit out of my expertise.
I had a look at the forms grid sample application, and that didnt work either - seemed to send the form, but ther was no data in the form, I wouldn't rule out that i was doing it wrong.
What i am trying to do is to schedule sending an email of the task list once a month to users of the next two months up coming task - only one user in this case, which keeps it simple.
Don't know if you have any suggestions on how this could be accomplished?
Hi, if the datalist is embedded using iframe or javascript then I would think the pdf export will not recognize it. You could try using one of the form grids instead of a datalist instead.
I followed the attached instructions to embed a datalist in a form, and i can see the datalist in my form.
Embed a datalist in a form
However when i send the form via email, the attached pdf is blank, and there is no datalist.
Can you advise what could be wrong - want to add disclaimer, am no way a web developer, but am very good with a search engine.
