Hi Guys,
I have create one form and in form I out one Textbox control for adding URL.
I want to save image in particular folder. Also, filename will be stored on particular table.
Can any one guide me for this?
I want some solution in Bean Shell Form Store Binder.
Thanks.
      Hi, BeanShell is Java code so you can use standard Java code to read contents from a URL e.g. https://stackoverflow.com/questions/4328711/read-url-to-string-in-few-lines-of-java-code
      There are some sample code for file handling and data storing in File handling in Bean Shell Form Store Binder and Store Form Field Data to Multiple Tables too.
