We have developed phase 1 of my web application in joget. Now we have published it and user are using it.
Now we got further requirement in it. and we want to work on it but it must not be disturbing for our users.
Is joget provide development environment where we can do modification and test it. and once everything is done we can publish it for users.
      Hi. Personally we have a development environment in "disconnected" with a Joget On-promise of the same version as that of the cloud, but in isolation. What we do regularly is download a complete copy of our server in production and restore it on a clean DB in the development and testing environment and we deploy like this. In the case of the Joget cloud, what you should do is export from the cloud including the data (it only works in Joget DX).
      The following, either by restoring the DB or doing an import process in your local development environment, in the process you already have you must create a new version (you know how?) And deploy it to make the new requirements. When you are sure that you have contemplated everything and have developed everything, you can do the export process from the development server but without including data and import it into your production environment.
