My date range filter on a data works fine.  But how do I get the date filter boxes to empty out so that the form will revert back to the full list?
      for a datalist accessed thru the userview menu and for a date range picker the little red X in the date field does not appear like it does for date pickers in the forms view. after some checking the page source (html) code, it looks like the datepicker.css is not loaded for datalists as compared to forms, so i added the following to the custom header box for userview when loading a datalist
      <link rel="stylesheet" href="/jw/plugin/org.joget.apps.form.lib.DatePicker/css/datePicker.css" />
      <style>
      .close-icon:after {
      right: 30px;
      position: relative !important;
      text-align: left;
      margin-left: 5px;
      margin-right: 10px;
      top: 2px ;
      </style>
      and it seems to work to clear the box on click.
      --- while it works and its very convenient, someone can tweak it to make it look like red circles instead of the oval like view it has compared with the circular view it should have
        Click on the menu again and all the filters will clear away.
        1. Bob Bonta
          I don't come to the datalist via a menu ... the datalist was loaded (filtered) from a different list where I selected a specific user.  After reviewing that filtered list, I want the option to either return from whence I came (already set up successfully), or simply refresh the list unfiltered.  The typical standard is to have some form of X to remove the filter ... that doesn't seem to be available in JOGET.
