Good day,
I am very new to this system and i would like to know does every form process require approval only than it can proceed to the next step ?
As currently I'm trying to create a form where the requestor will fill in the information and it will directly send to the process owner. A very simple 1 to 1 but it keep failing to send the assignment notification to the process owner. The only time it work for the assignment notification is when i directly run the process.
  1. Ian
    what errors are you getting?
    can you take a screenshot of your process flow?
  2. Aaron Tan
    Good day,
    After playing with the system feature more, I am finally able to get an output. Kindly refer below for the sample
    Hi, how tasks are assigned depends on how you design your process. How is your current process design? You may want to check out Designing a Process for the basics of designing a process.
