I'm using the file upload page in joget, I need to access the file content from the backend using JSON Tool.  suggest some ways..
      Hi, if you require custom behavior that is not provided by default, you can try implementing your own plugin. There is a related open source project at https://github.com/jogetoss/enhanced-json-tool, you could try to start from there.
