Is it possible that, like Enterprise support, Joget API Builder is turned off on the AWS Marketplace instances of Joget. I have tried both the Windows and the Ubuntu instances. Although, on the OAS3 Document, Swagger UI tab, the "Try it out" option seems to work, at least on the Ubuntu version, I have never been able to make the created APIs work either from Postman or from internal JSON Tool calls. In both cases, they always return "HTTP Status 400 – Bad Request." I have tried all possible whitelist variables in General Settings and in the API settings. If this is the case that they are disabled this should be noted somewhere. If not, could someone experienced suggest what setting or configuration I may have missed. Thanks!
      Hi, have you tried to look into your network configuration? Are you accessing your instance through a reverse proxy or load balancer? If so, try accessing the app server directly to see if it makes any difference.
      1. William Vasu
        Hi Anders, and thanks for all the expertise and wisdom you share with our community!
        I have tried this. I am on a Windows 2019 server if that is relevant. I have tried this as recently as today making an API call from Postman on the very same computer on which Joget Enterprise version is installed and has been working perfectly with the exception of recognizing these API calls. The same things seems to happen by making the calls from JSON tools as well - 400 - Bad request. In a browser, also on the same computer, URLs with paths as far down as http://localhost:8080/jw/web/ work just fine but adding /json and additional paths below that are not accepted. In particular the API we need is a POST of this form http://localhost:8080/jw/web/json/data/form/store/ifcsnsandbox/grantTerms/001 to create a form record but it will only give a consistent 400 - Bad request. Is there something unique about a Windows installation of Joget that may be involved? The API domain whitelist in Settings is currently * but we have tried many various combinations to no avail. Thanks!
