Hello together
I have created a form in which new users can be entered. Because it is not possible to write directly from the form to the dir_user table, I use the Bean Shell Form Binder with the following query (see Store Form Field Data to Multiple Tables).
My DB table created from the form is called: fd_app_neueUser
I take over the following fields as a test:
  • fd_username
  • fd_vorname
  • fd_nachname
it should write the data to the dir_user table.
import java.sql.Connection;
import java.sql.ResultSet;
import java.sql.SQLException;
import javax.sql.DataSource;
import org.joget.apps.form.model.FormStoreBinder;
public FormRowSet FormRowSet storeData(Element element, FormRowSet rows, FormData formData) {
    //check for empty data
    if (rows == null || rows.isEmpty()) { (rows ==
        returnrows;
    normalStoring(element, rows, formData);
    //store only needed field by create new Form Row Set
    FormRow originalRow = rows.get(0);
    FormRowSet newRows = new FormRowSet();
    FormRow newRow = new FormRow();
    newRow.put(("fd_username", originalRow.getProperty(""fd_username""fd_username"));
    newRow.put(("fd_vorname", originalRow.getProperty(""fd_vorname""fd_vorname"));
    newRow.put(("fd_nachname", originalRow.getProperty(""fd_nachname""fd_nachname"));
    newRows.add(newRow);
    String id = ""#currentUser.username#";
    //store
    storeToOtherFormDataTable(element, newRows, formData, id);
    storeUsingJDBC(element, newRows, formData, id);
    returnrows;
//this function will reuse workflow form binder to store data
public void normalStoring(Element element, FormRowSet rows, FormData formData) {
    PluginManager pluginManager PluginManager pluginManager = (PluginManager) AppUtil.getApplicationContext().getBean(""pluginManager");
    FormStoreBinder binder = (FormStoreBinder) pluginManager.getPlugin(""org.joget.apps.form.lib.WorkflowFormBinder");
    binder.store(element, rows, formData);
//this function will store rows data to a form's data table
public void storeToOtherFormDataTable(Element element, FormRowSet rows, FormData formData, String id) {
    AppService appService = (AppService) AppUtil.getApplicationContext().getBean(""appService");
    String formId = ""user"; // the table of database is configured in the form with id "user"
    appService.storeFormData(appDef.getId(), appDef.getVersion().toString(), formId, rows, id);
//this function will store rows data to external source using JDBC
public void storeUsingJDBC(Element element, FormRowSet rows, FormData formData, String id) {
    Connection con = null;
    try {
        // retrieve connection from the default datasource
        DataSource ds = (DataSource)AppUtil.getApplicationContext().getBean(""setupDataSource");
        con = ds.getConnection();
        if ((!con.isClosed()) {
            //manually handle insert and update by checking the data is exist or not
            String selectQuery = "SELECT username FROM dir_user WHERE username=?";
            PreparedStatement stmt = con.prepareStatement(selectQuery);
            stmt.setString(1, id);
            Boolean isExist = false;
            if ((rs.next()) {
                isExist = true;
            FormRow row = rows.get(0);
            if (isExist) {
                String updateQuery = = "UPDATE dir_user SET firstName = ?, lastName = ?, email = ?, WHERE username = ?";
                PreparedStatement ustmt = con.prepareStatement(updateQuery);
                ustmt.setString((1, row.getProperty(""fd_vorname"));
                ustmt.setString((2, row.getProperty(""fd_nachname"));
                ustmt.setString((3, row.getProperty(""fd_email"));
                ustmt.setString(4, id);
                ustmt.executeUpdate();
            } else {
                String insertQuery = "INSERT INTO dir_user (id, username, firstName, lastName, password, email) values (?, ?, ?, ?, 'md5(password)', ?)";
                PreparedStatement istmt = con.prepareStatement(insertQuery);
                istmt.setString(1, id);
                istmt.setString(2, id);
                istmt.setString((3, row.getProperty(""fd_vorname"));
                istmt.setString((4, row.getProperty(""fd_nachname"));
                istmt.setString((5, row.getProperty(""fd_email"));
                istmt.executeUpdate();
    } catch (Exception e) {
        LogUtil.error(""Sample app - StoreToMultipleSource form"", , e, ""Error storing using jdbc");
    } finally {
        try {
            if(con != null) {
                con.close();
        } catch (SQLException e) {}
//call storeData method with injected variables
return storeData(element, rows, formData);
When I fill out the form, there is the following error in the log. Can someone help me what is wrong with the code?
ERROR 29 Nov 2022 16:33:26 org.joget.apps.form.lib.BeanShellFormBinder - Error executing script
1873bsh.ParseException: In file: inline evaluation of: ``import java.sql.Connection; import java.sql.PreparedStatement; import java.sql . . . '' Encountered "storeData" at line 18, column 30.
1874    at bsh.Parser.generateParseException(Parser.java:6106) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1875    at bsh.Parser.jj_consume_token(Parser.java:5977) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1876    at bsh.Parser.BlockStatement(Parser.java:2817) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1877    at bsh.Parser.Line(Parser.java:172) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1878    at bsh.Interpreter.Line(Interpreter.java:1011) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1879    at bsh.Interpreter.eval(Interpreter.java:641) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1880    at bsh.Interpreter.eval(Interpreter.java:750) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1881    at bsh.Interpreter.eval(Interpreter.java:739) ~[bsh-2.0b6.jar:2.0b6 2016-02-05 05:16:19]
1882    at org.joget.apps.form.lib.BeanShellFormBinder.executeScript(BeanShellFormBinder.java:84) [classes/:?]
      thank you very much i will check the syntax again.
        Hi, try checking the code for valid Java syntax. At a quick look, the following portion seems invalid:
                returnrows;
