I begin use Joget Workflow
and i need to get Variable from external Application
so, i use JSON API,
when i set the url:
http://localhost:8080/jw/web/json/workflow/process/start/Eywa:7:LeaveApplicationProcess?j_username=samir&hash=C80ED828133D9F3F60E31E2AE22AC951
result : {"error":{"message":"","code":"400","date":"Thu Jan 14 08:57:06 IST 2016"}}
      If you're using v5, there is a new security setting API Domain Whitelist in General Settings. You need to set it to allow external API calls.
        Could you let us know what you're trying to achieve?
        Do you want to start a Joget Workflow Process via a REST API?
        Thanks,
        Ashutosh
