I have a time entry form in Joget DX7 for a day with a grid allowing to indicate several lines of reason and a quantity of hours which calculates a total number of hours.
Example:
date 01/04/2023
        project 1 : 2h
        project 2 : 3h
Total for the 01/04/2023 : 5h
I would like to display on the form, before the submission an information message if the total is lower or higher than a value stored in base for the day.
For example, for 01/04/2023 theorical value is: 8h.
The desired message should be :
      if the total duration > theoretical duration message = "exceeded",
      if total duration < theoretical duration, message: "incomplete".
I have done this in a datalist with sql but it is after submission.
How to do this before submission ?
      Hi, to do this before the form submission, you would want to make use of custom JavaScript. Insert a Custom HTML element, and place your custom JavaScript there. There should be many script examples out there, for example https://stackoverflow.com/questions/68967211/display-a-message-based-on-variable-value
