I have a grid on a form that I want to pre-populate from and external datasource. I have tried both the Bean Shell and JDBC binders but nothing prepopulates. The database connection test succeeds and the query I am using has been used previously to populate a dropdown list (see dropdown question).
Thank you for you help.
      Have you had a look at Pre-populate Form Fields with Data from External Source? It might be quite similar to what you're trying to achieve.
