Hi!, i will be using condition helper in the process, what will be my syntax?
the condition is,
if the Worlkflow Variable "desti" has a word "Cebu" in it, regardless if it is "Cebu, Tanao" or "Cebu, Dalisay".
as long as the word "Cebu" is in. it will go to that process. how will i use that in the condition helper. what will be my syntax when using the "%like' syntax. thanks!
      Hi Jedi
      Workflow process conditions are actually JavaScript comparison operators.
      For your special case, set 'Use Condition Helper' to 'No' and enter this string into the 'Condition' field in 'Transition Properties':
         /Cebu/gi.test(desti) === true
      The '/g' means global match and '/i' means ignore case.
      Do some research about JavaScript RegExp and RegExp.prototype.test() functions.
      1. jedi
        Hi Matthew! thank you so much for this! it works! yeah, i am new to joget and javascript. im sorry
      2. Matthew King
        No problems Jedi, in IT world, we are all learning. Sorry I should hv reword the last sentence as "You can find out more about JavaScript RegExp and RegExp.prototype.test() functions." :-) Happy Joget Building!
