Hi, there is not enough information to help, there is no indication of what your BeanShell code does. Also, try checking for errors or traces in the logs.
I am triggering one process that has some Java code in the BeanShell tool. but when I start the process, it retriggers automatically again after 2-3 minutes. in my Java code, I am fetching data from Oracle data Based on the Joget database. data that I am fetching is nearly 70000+ in count. the process triggers again after the whole data is migrated to the Joget database or after 2-3 minutes.
How can I resolve this issue?
Please share Beanshell script
