Dear Expert,
I have a form which contain sub form for read only. However when I save that form the field inside the subform will be created in the database.
How can we attached the subform without creating any db fields ?
Best Regards
Tony Chu
      Dear Matthew,
      After more investigation, the unwanted field actually is created by JDBC Load Binder for a grid and not subform.
      I have this SQL in JDBC Load binder:
      Select id, c_partCode, c_description from app_fd_testTable;
      and the form table will create the following extra fields
      c_c_partCode, c_c_description.
      Best Regards
      Tony Chu
      1. Eric
        very interesting - I have run into this problem myself before but I couldn't find out where it comes from or how to reproduce it. I assumed my SQL script was faulty....
      Hi Tony Chu
      Is the field/table_column which you don't want created in DB table, already exist in another table? If yes, make that subform to point to your DB table with the existing table_column, then no new table_column will be created.
