Hi, you need to close your resources especially the connection within a finally block https://stackoverflow.com/questions/32816875/why-jdbc-connections-needs-to-close-in-finally-block. Otherwise there will be a leak when an exception happens.
Joget log keep warn possible unclosed DB connections. What is wrong with my scripting.
import java.sql.*;
import javax.sql.DataSource; // add this
import org.joget.apps.app.service.AppUtil; // add this
import org.apache.commons.collections.SequencedHashMap;
import java.util.*;
public FormRowSet getIslas() {
FormRowSet f = new FormRowSet();
f.setMultiRow(true);
Connection con = null;// add this
DataSource ds = (DataSource)AppUtil.getApplicationContext().getBean("setupDataSource");// add this
con = ds.getConnection();// add this
if(!con.isClosed()){
String sql = "SELECT DISTINCT dir_employment.userId, dir_employment.departmentId, dir_department.id, dir_department.name, dir_department.hod, dir_user.username, dir_user.firstName FROM dir_employment INNER JOIN dir_department ON dir_employment.departmentId=dir_department.id INNER JOIN dir_user ON dir_user.username=dir_employment.userId";
PreparedStatement stmt = con.prepareStatement(sql);
FormRow r1 = new FormRow();
r1.put(FormUtil.PROPERTY_VALUE, "");
r1.put(FormUtil.PROPERTY_LABEL, "-- PLEASE CHOOSE --");
f.add(r1);
while (rs.next()) {
FormRow r2 = new FormRow();
r2.put(FormUtil.PROPERTY_VALUE, rs.getString("userId"));
r2.put(FormUtil.PROPERTY_LABEL, rs.getString("firstName"));
r2.put(FormUtil.PROPERTY_GROUPING, rs.getString("departmentId"));
f.add(r2);
rs.close();
stmt.close();
con.close();
return f;
return getIslas()
