Is their a way to show the time properly in Joget Calendar?
It is showing 1:10a instead of 1:10 am
Can we make it correct
      i found the calendar plugin is using https://fullcalendar.io.
      u can use the following script to set the format. Other formats can refer to https://fullcalendar.io/docs/utilities/date_formatting_string/.
      $('#fullcalendar').fullCalendar('option', 'timeFormat', 'h(:mm)a');
      1. Jahan Zaib Yousaf
        Thanks Do you know where we can put it or we have to modify the Calendar Plugin ?
      2. Jahan Zaib Yousaf
        Thanks i figured out we can put in the HTML control of Calendar
