I am trying to connect from a Joget hosted cloud instance of Joget to a MySQL database on AWS using Configure Datasource > Configure Custom Database. When I test it seems to almost connect but I get the error:
Cause:
Cannot create PoolableConnectionFactory (Access denied for user 'mysqlroot'@'ec2-54-193-24-224.us-west-1.compute.amazonaws.com' (using password: YES))
These credentials work just fine from other non-Joget applications.
Why does this not work as expected?
Thanks, Bill
      Thanks for your provided information. I managed to replicate your issue with password containing "$' character. This issue is fixed. Our team will inform you when a new release is available. For a temporary solution, can you remove the "$" character from your password? Sorry for any inconvenience caused.
      Best regards.
        Also in the log, I notice the error “java.lang.IllegalArgumentException:" at the beginning of this section before the first error regarding authentication " java.sql.SQLException:” (see below). Could the first error be causing the issue?
         at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
         at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
         at java.lang.Thread.run(Unknown Source)
        2017-09-02 15:50:45,667: java.lang.IllegalArgumentException: Illegal group reference: group index is missing
         at java.util.regex.Matcher.appendReplacement(Unknown Source)
         at java.util.regex.Matcher.replaceAll(Unknown Source)
         at java.lang.String.replaceAll(Unknown Source)
         at org.joget.commons.util.StringUtil.decryptContent(StringUtil.java:442)
         at org.joget.apps.app.service.AppUtil.processHashVariable(AppUtil.java:428)
         at org.joget.apps.app.service.AppUtil.processHashVariable(AppUtil.java:410)
         at org.joget.apps.app.controller.DatalistBuilderWebController.createDataListBinderFromRequestInternal(DatalistBuilderWebController.java:299)
         at org.joget.apps.app.controller.DatalistBuilderWebController.getBuilderDataColumnList(DatalistBuilderWebController.java:211)
         at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
         at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
         at java.lang.reflect.Method.invoke(Unknown Source)
         at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:180)
         at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
         at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
         at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
         at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
         at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:43)
         at org.joget.apps.app.web.JsonResponseFilter.doFilter(JsonResponseFilter.java:138)
         at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
         at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
         at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
         at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80)
         at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
         at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:799)
         at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
         at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1455)
        2017-09-02 15:50:45,672: java.sql.SQLException: Cannot create PoolableConnectionFactory (Access denied for user 'mysqlroot'@'ec2-54-83-5-152.compute-1.amazonaws.com' (using password: YES))
        1. Julian
          Hi William, Yes the error message "java.lang.IllegalArgumentException: Illegal group reference: group index is missing" does seem like a possible cause, although it's difficult to tell at this point without more information. If you could provide a sample app or detailed steps to reproduce the error, then we can help to have a look. Best Regards Julian
        Hi Anders,
        No, I have now tried to access this same database in a simple datalist. I have verified that the correct credentials have been entered because if I change the password to anything else I get
        But it I use the correct password, I get
        But when when I click ok in the Custom Datasource screen, i get
        The corresponding error in the log is
        2017-09-02 15:50:45,674: java.lang.RuntimeException: java.sql.SQLException: Cannot create PoolableConnectionFactory (Access denied for user 'mysqlroot'@'ec2-54-83-5-152.compute-1.amazonaws.com' (using password: YES))
        The SQL Query is simple and correct
        SELECT * FROM x2_churches
        It appears that when the Query request is made the same/proper credentials are not being used as for the connection test.
        How can I get this resolved?
        Thank, Bill
          I thought this might be the case so I tried it on an enterprise self-hosted version. Now I get
          When I create the Custom Datasource for the Jasper Reports plugin. This looks correct.
          However, then why I try to execute the same report from the userview I get
          Can this plug not use current TIBCO Jaspersoft Studio jrxml files?
          Thanks, Bill
          1. Anders
            Hi, in this case the error message says "Access denied for user" which actually indicates that the authentication failed. Perhaps its some incorrect jdbc configuration in the jrxml file.
          Hi, I believe this is due to security restrictions as mentioned in Problem connecting external Database in Joget onDemand
