Maybe you can try this :
Navigate to Apache folder > webapps >
Copy & paste the jw folder in the webapps folder and rename that to whatever you want. Say : /fmv
if you quickly look at the console,it will start reading from the new name .
Then ,restart joget and replace the /jw in the url with the /fmv and u are good to go..
This way there won't be any trouble.
You will have url like this :/fmv is there
Mind that, this is only redirection not masking. In other words, we cannot completely change the URL.
when submitted, it does not submit to /fmv but to /jwa.instead.
It means,
Whenever you enter /fmv it will be redirect to /jwa .
Hope you understand and help with your concern.
Cheers!
may i ask how to chang the login url to /fmv or is it not possible?
im using my own server
