Hello everyone, Can I use a variable in a workflow variable without it being bound to any field in the forms? If the answer is yes, how can I give this variable a value to store in it from the Beanshell js code tool in the process?
Because I do that but it doesn't work, please some help
      The answer is yes. You can either use Setting Workflow Variable Value in Process Tool Bean Shell or using a plugin that is available in the marketplace https://marketplace.joget.com/jw/web/userview/mp/mpp/_/vad?id=WVariable_Update_Tool-1
      However, For beanshell, it should be in Java format. Not javascript.
