show data use: load binder: JDBC Binder
Store Binder: Bean shell form binder
load data/appear data succes (im used query), problem :but if i want edit direct on grid after save data already saved on database but cant appear on that grid
      Hi, I think your bean shell form binder did not handle the edit data correctly which causing the load is not working. You may need to review it.
