Is there away i can access an app's database Source, I've seen it in the knowledge base but i don't know how to access it.
      Assume that you using Joget Cloud for On-demand with shared server, so it does not allow to access DB because in could impact with other account's database. That's why Joget on cloud disable "Datasource & Profile" menu in Setting screen.
        you can use any tool to connect to the database using the credentials you used while installing joget.
        1. layal
          I am using joget in cloud so i did't install it locally
