i found error in joget.log
ERROR 20 Jul 2018 16:01:33 org.joget.plugin.enterprise.JdbcDataListBinder  - com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ';
/*SELECT
    c.c_clientName,
    c.c_clientType,
    m.c_name1,
    p.c_insu' at line 15
/*SELECT
    c.c_clientName,
    c.c_clientType,
    m.c_name1,
    at sun.reflect.GeneratedConstructorAccessor214.newInstance(Unknown Source)
    at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
    at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
    at com.mysql.jdbc.Util.handleNewInstance(Util.java:404)
    at com.mysql.jdbc.Util.getInstance(Util.java:387)
    at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:941)
    at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3870)
    at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3806)
    at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2470)
    at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2617)
    at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2550)
    at com.mysql.jdbc.PreparedStatement.executeInternal_aroundBody10(PreparedStatement.java:1861)
    at com.mysql.jdbc.PreparedStatement$AjcClosure11.run(PreparedStatement.java:1)
    at org.aspectj.runtime.reflect.JoinPointImpl.proceed(JoinPointImpl.java:149)
    at org.joget.commons.util.AnalyzerAspect.analyzeSql(AnalyzerAspect.java:122)
    at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1832)
    at com.mysql.jdbc.PreparedStatement.executeQuery_aroundBody12(PreparedStatement.java:1962)
    at com.mysql.jdbc.PreparedStatement$AjcClosure13.run(PreparedStatement.java:1)
    at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1922)
    at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
    at org.joget.plugin.enterprise.JdbcDataListBinder.executeQueryCount_aroundBody32(JdbcDataListBinder.java:373)
    at org.joget.plugin.enterprise.JdbcDataListBinder.executeQueryCount_aroundBody33$advice(JdbcDataListBinder.java:94)
    at org.joget.plugin.enterprise.JdbcDataListBinder.executeQueryCount(JdbcDataListBinder.java:1)
    at org.joget.plugin.enterprise.JdbcDataListBinder.getDataTotalRowCount_aroundBody16(JdbcDataListBinder.java:137)
    at org.joget.plugin.enterprise.JdbcDataListBinder.getDataTotalRowCount_aroundBody17$advice(JdbcDataListBinder.java:94)
    at org.joget.plugin.enterprise.JdbcDataListBinder.getDataTotalRowCount(JdbcDataListBinder.java:1)
    at org.joget.apps.datalist.model.DataList.getTotal(DataList.java:460)
    at org.joget.plugin.enterprise.DataListInboxMenu.getDecoratedMenu_aroundBody18(DataListInboxMenu.java:112)
    at org.joget.plugin.enterprise.DataListInboxMenu.getDecoratedMenu_aroundBody19$advice(DataListInboxMenu.java:94)
    at org.joget.plugin.enterprise.DataListInboxMenu.getDecoratedMenu(DataListInboxMenu.java:1)
    at org.joget.apps.userview.model.UserviewMenu.getMenu_aroundBody8(UserviewMenu.java:95)
    at org.joget.apps.userview.model.UserviewMenu.getMenu_aroundBody9$advice(UserviewMenu.java:94)
    at org.joget.apps.userview.model.UserviewMenu.getMenu(UserviewMenu.java:1)
    at sun.reflect.GeneratedMethodAccessor253.invoke(Unknown Source)
    at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:840)
    at freemarker.ext.beans.BeanModel.invokeThroughDescriptor(BeanModel.java:276)
    at freemarker.ext.beans.BeanModel.get(BeanModel.java:183)
    at freemarker.core.Dot._getAsTemplateModel(Dot.java:76)
    at freemarker.core.Expression.getAsTemplateModel(Expression.java:89)
    at freemarker.core.Expression.getStringValue(Expression.java:93)
    at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
    at freemarker.core.Environment.visit(Environment.java:210)
    at freemarker.core.MixedContent.accept(MixedContent.java:92)
    at freemarker.core.IteratorBlock$Context.runLoop(IteratorBlock.java:179)
    at freemarker.core.Environment.visit(Environment.java:417)
    at freemarker.core.IteratorBlock.accept(IteratorBlock.java:102)
    at freemarker.core.IfBlock.accept(IfBlock.java:82)
    at freemarker.core.ConditionalBlock.accept(ConditionalBlock.java:79)
    at freemarker.core.Environment.process(Environment.java:190)
    at freemarker.template.Template.process(Template.java:237)
    at org.joget.plugin.base.PluginManager.getPluginFreeMarkerTemplate(PluginManager.java:967)
    at org.joget.apps.userview.service.UserviewUtil.getTemplate(UserviewUtil.java:78)
    at org.joget.apps.userview.service.UserviewUtil.getTemplate(UserviewUtil.java:59)
    at org.joget.apps.userview.model.UserviewV5Theme.getMenus_aroundBody26(UserviewV5Theme.java:152)
    at org.joget.apps.userview.model.UserviewV5Theme.getMenus_aroundBody27$advice(UserviewV5Theme.java:94)
    at org.joget.apps.userview.model.UserviewV5Theme.getMenus(UserviewV5Theme.java:1)
    at org.joget.plugin.enterprise.JanuxV5Theme.getMenus_aroundBody28(JanuxV5Theme.java:153)
    at org.joget.plugin.enterprise.JanuxV5Theme.getMenus_aroundBody29$advice(JanuxV5Theme.java:94)
    at org.joget.plugin.enterprise.JanuxV5Theme.getMenus(JanuxV5Theme.java:1)
    at org.joget.apps.userview.service.UserviewThemeProcesser.getMenus(UserviewThemeProcesser.java:511)
    at org.joget.apps.userview.service.UserviewThemeProcesser.getHtml(UserviewThemeProcesser.java:185)
    at sun.reflect.GeneratedMethodAccessor349.invoke(Unknown Source)
    at javax.el.BeanELResolver.getValue(BeanELResolver.java:97)
    at org.apache.jasper.el.JasperELResolver.getValue(JasperELResolver.java:110)
    at org.apache.el.parser.AstValue.getValue(AstValue.java:167)
    at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:184)
    at org.apache.jasper.el.JspValueExpression.getValue(JspValueExpression.java:115)
    at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspx_meth_c_005fset_005f0(v5view_jsp.java:223)
    at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspx_meth_c_005fif_005f0(v5view_jsp.java:185)
    at org.apache.jsp.WEB_002dINF.jsp.ubuilder.v5view_jsp._jspService(v5view_jsp.java:138)
    at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
    at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:431)
    at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:396)
    at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:340)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
    at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:721)
    at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:466)
    at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:391)
    at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:318)
    at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:168)
    at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:303)
    at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1244)
    at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1027)
    at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:971)
    at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
    at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:966)
    at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:857)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:618)
    at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:842)
    at org.joget.commons.util.AnalyzerFilter.doFilter_aroundBody0(AnalyzerFilter.java:17)
    at org.joget.commons.util.AnalyzerFilter$AjcClosure1.run(AnalyzerFilter.java:1)
    at org.joget.commons.util.AnalyzerAspect.analyzeRequests(AnalyzerAspect.java:54)
    at org.joget.commons.util.AnalyzerFilter.doFilter(AnalyzerFilter.java:17)
    at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
    at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
    at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
    at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
    at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
    at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:122)
    at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:48)
    at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
    at org.joget.apps.workflow.security.WorkflowHttpAuthProcessingFilter.doFilter(WorkflowHttpAuthProcessingFilter.java:84)
    at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:120)
    at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:64)
    at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:53)
    at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
    at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
    at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
    at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:344)
    at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:261)
    at org.joget.commons.spring.web.CustomDelegatingFilterProxy.doFilter(CustomDelegatingFilterProxy.java:30)
    at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:43)
    at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:85)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
    at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:516)
    at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1086)
    at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:659)
    at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223)
    at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1558)
    at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1515)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
    at java.lang.Thread.run(Thread.java:745)
it show part of sql but not detail about form name or list name.
for fix this probleam i must find in all form and list.
may other way to find root of probleam form?
      Hi, you can try to search in the JSON definition in Builder Advanced Tools#JSONDefinition. That way you can directly see which datalist contains that sql query.
      1. pitt phunsanit
        JSON definition shows only the current form only. sometimes i find by this query. SELECT * FROM app_form WHERE json LIKE '%some string%' but it can't directly refer to error form.
