I have installed Joget Workflow v6.0.9 and able to login using these credentials(username:admin,pwd:admin).
Didn't get any page for database configuration as mentioned in the joget docs(JOGET docs.png).
How to proceed further in connecting Joget Workflow with Sqlite database.
      You can create new database connection profile by setting up new db profile like this.
        I think it comes preinstalled with mysql. To use other db, try these steps.
        You will need to:-
        1. Shutdown joget server
        2. Get sqlite jdbc driver (.jar file) - http://www.sqlitetutorial.net/sqlite-java/sqlite-jdbc-driver/ and put into tomcat/webapps/jw/WEB-INF/lib folder.
        3. Go to wflow/app_datasource.properties. Add a # to the front of the line.
          #currentProfile=default
        4. Start joget server.
        5. You will now see this screen Setting Up Database
        6. Key in the sqlite jdbc path like the article in step 2 and configure the rest accordingly.
