When File Upload is used it populates an error of invalid date format
        Hey ashvitha,
        Do check your field IDs for the date picker and file upload, if there's a conflict (eg: same form field ID).
        Hope this helps.
        1. ashvitha
          Hi Justin, The form is saved but i din't find the field in datalist of my app. i have attached a screenshot in answer section
        2. Justin
          Hi there, what I meant with my answer here is, edit the form related to the form you've attached previously, and edit the date picker and the file upload field element, and compare both Field IDs to see if there is any conflict (eg: same field IDs). Take a screenshot of the date picker and file upload configuration if you have more doubts on this. Hope this helps.
        3. ashvitha
          Hello, I did that precedingly, and the form details got saved in datalist(here UserList).Series of dates which u see in the attachment is File Upload section. Dates are generated at the place of File Upload in the userview
          Hey ashvitha,
          File Upload is supported in V6 community edition.
          Is it possible to list down the steps to replicate this issue? Or provide server log (if any errors)? Or sample app? Or screenshot of the issues?
          Thanks.
          1. ashvitha
            Hi, 1.I have added file upload in my form 2.When i upload some file inside file upload. 3. It populates the value in the date picker field and completely forgets about the file which was updated. I have attached the screenshot in answer section.
          2. ashvitha
            Any solution plz
