Hi, am not very familiar with JasperReports but according to https://stackoverflow.com/questions/3360831/relative-path-for-the-subreport/3387463#3387463, you can't use relative paths. Perhaps you could try to put the file in a path on your server and try to use an absolute path to see if it works.
Hello team. I have a problem, I need to implement, in Jasper, a report that contains subreports. In general, Jasper calls these subreports in the following way:
However, where should I then put the Blank_A4_3.jasper file on the server in order to implement this requirement? Should another type of procedure be done for this implementation?
