When a form(1) is submitted there is no generation of message in inbox.
But i have added run process(2) in my userview and when i run the process, only then i get a message in inbox.
      Hey there,
      Using the Form Userview Menu, it is used only as a method to add new records into the table. It is not related to a process.
      Assignments are only issued to users via process activities.
      Hope this clarifies.
      1. ashvitha
        Hi justin, How will the record saved in datalist can be assigned to an user.
      2. Justin
        Hey there, You can create a process to assign tasks to users. Then, you can use a Datalist Inbox to use back your intended datalist to display appropriate information.
