Can i customize the attached form completely.If yes, how.
      Unfortunately, it is not possible to modify system elements easily.
      You can go to your Admin Bar --> Settings --> General Settings, under the "User Interface Settings", you can find the custom CSS and CSS URL field for your use.
      1. ashvitha
        Hello justin, I added a text box in css it was added to all the pages of joget. Want fields only to be added in the attached form.
      2. ashvitha
        attached form is create new user
