I have created the following Forms.
Form A: Contains multi-paged form (5 page)
Form B: Contains multi-paged form (3 page)
Form C: Contains multi-paged form (3 page)
Main Form
Contains Radio buttons for users to select their type.
The subform is hidden initially, and will only be displayed once user selects a type. Each type is tied to a form.
Type A = Form A | Type B = Form B | Type C = Form C
The bug found is in the Main Form:
  • The Next button of the first Subform Multi-page is disabled.
  • To go to the 2nd page, I am required to use the wizard/tab label.
  • However, once I clicked on the other pages and go back to the 1st page, the Next button is not disabled anymore.
  • This applies to all the subforms.
Can please help to advise what I can do to get the Next button not disabled for the first page?
I am using Version: 6.0.11 and V6 Universal Theme
      Hi Anders,
      There is no custom code in the form.
      I noticed that the button is disabled related to the Visibility Control.
      Have you built the form as the following scenario? Maybe it was not clear before.
      Main Form
      1 - Contains Radio buttons for users to select their type.
      2 - There are 3 separate Sections that contains 1 Subform.
      3 - Each Subform tied to Form A or Form B or Form C.
      4 - The Visibility will be controlled by the Type the user choose.
      Example: Select Type A will display a section with Subform tied to Multi-page Form A
      I tried to remove the visibility rules, and all the multi-page 1st-page Next button is working correctly. So I think it is a bug that is related to Visibility.
        Hi, in my multi-page forms the Next button is not disabled. Is there any custom code in your form that disables it?
        1. Harita
          Please refer to below for further clarification. Thanks.
