Hi all,
My question is, if add new javascript library into joget, does it effect the joget itself? Thank you for your time.
      Hey there izzat,
      Joget already comes with its own jQuery library. It is not advisable to upgrade jquery since it may break a lot of functionality.
      Other than that, you can certainly try to add a Javascript library into your Joget Forms or Userview or etc. Just note about the scope of effect on where you place the Javascript code to call the library.
      Hope this clarifies.
      1. izzat
        Thank you justin
