Hi, I believe this could be due to security restrictions as mentioned in Problem connecting external Database in Joget onDemand
Matthew, Thanks for your advice~~
I have include the field name in "Primary Key" already....
I am using cloud version of Joget to test, so I cannot find the log. cloud named: "duraflex.cloud.joget.com"
May I know how I can get the log for cloud version? Thanks!!
In Configure Datalist Binder, the field "Primary Key" must be a field name that exists in your database table.
Also do check the "C:\...\apache-tomcat-8.5.23\logs\joget.log" file for detail explanation of the reason why the JDBC SQL failed.
Thank you.
I have tried a lot of times and cannot get the data from external database.I connected the Databased but I cannot get the data to the column list.
Below is the pic of my setting
Test connection success
Fail to get the data.
Below is my SQL table. And I have tried all below SQL option to run and fail. Please help~~
SELECT * FROM s729nownetcn.dbprojectdevelopmenthk.dbo.BrandInfo
SELECT * FROM dbprojectdevelopmenthk.dbo.BrandInfo
SELECT * FROM dbo.BrandInfo
SELECT * FROM BrandInfo
