Try locally first, sometimes Google actually block it due to security reasons even though credential is correct. Try this https://devanswers.co/allow-less-secure-apps-access-gmail-account/ to enable "less secure access" or if you are using multi factor authentication, you can generate "app specific password" in your google account security settings too.
Hi, recently i had tried using joget cloud to test joget applications. I try to use email tool to send test email by using smtp gmail. Then i got this error. Before this, when using the localhost everything fine but joget cloud i am not sure about the setting of smtp.
