trying to work out a hyperlink action to display a detail page for an item in the datalist.
Hyperlink is
https://app2.clarizen.com/Clarizen/Ext/WidgetObjectDetailsPage.aspx?wt=ViewObjectDetails&
parameter is set to a form field that has the following content:
uid=9.633544.234274&wid=ijZM6UT9ikmMbRT_rwQvmA&pid=453.5725549.274345&urgs=1&vid=351.45541889.274345&doid=6.9601025.4345&el=0&CSig=8A016476D3B5FA2C05CB1D8F05F118CF3D8
when I go to the hyperlink in the userview, it does not populate the parameter with the hyperlink, instead it only shows the hyperlink portion.
I used simpler parameter and it worked. I changed it to this long one and it doesn't.
Is this a bug?
      thank you Walter. That explains.
        That's an interesting use case, it is correct that Joget encodes the characters so that values will be passed over correctly as a single parameter value. It did not expect the values to be chain of parameters and values.
        I guess we can create another hyperlink action plugin without this line of code (line 137)
        return (paramValue != null) ? URLEncoder.encode(paramValue, "UTF-8") : null;
        See the source code at https://github.com/jogetworkflow/jw-community/blob/6.0-SNAPSHOT/wflow-core/src/main/java/org/joget/apps/datalist/lib/HyperlinkDataListAction.java#L137
          did some more test, changed Hyperlink to
          made the parameter as
          WidgetObjectDetailsPage.aspx?wt=ViewObjectDetails&uid=9.633544.234274&wid=ijZM6UT9ikmMbRT_rwQvmA&pid=453.5725549.274345&urgs=1&vid=351.45541889.274345&doid=6.9601025.4345&el=0&CSig=8A016476D3B5FA2C05CB1D8F05F118CF3D8
          Now the parameter is added to the tail of the hyperlink, however it seems that the system encoded some of the characters, for example ? becomes %3F, "=" becomes %3D. This made the hyperlink unusable.
          How do I prevent the system from encoding the characters and just use the original character?
