Once an user uploads office document, is it possible to open the file in MS Office application by clicking on the file? so far I can only do that for PDF files; MS Office file would prompt a download instead of opening directly in the office application; also the extension has a "_" added to the end, e.g., docx will become "docx_".
thanks in advance.
      hi Anders, I have tried that, and it worked.
      thank you.
        Hi, you can try toggling the "Download as Attachment" option in the File Upload to see if it helps.
