hai. Currently i am facing issue on order by method which is I want order by 3 variable or field ID in Ascending. I only can use 1 variable or field ID. Can someone help me, how to use variable in same time?
      Hi, you can try to do the ordering in your binder itself. For example if you are using the JDBC Datalist Database Binder you could try adding your own order by clause.
