I have completed building the source code according to the link below.
However, there is no 'jw.war' file in the 'wflow-consoleweb' folder.
Where can I get the 'jw.war' file?
https://dev.joget.org/community/display/KBv6/Build+Source+Code+on+Linux
[INFO] --- maven-install-plugin:2.4:install-file (default-cli) @ wflow-app ---
[INFO] Installing /home/parallels/joget/ojdbc6.jar to /root/.m2/repository/com/oracle/ojdbc6/12.1.0.2/ojdbc6-12.1.0.2.jar
[INFO] Reactor Summary:
[INFO]
[INFO] wflow-jdbc ......................................... SUCCESS [ 0.129 s]
[INFO] wflow-commons ...................................... SUCCESS [ 0.016 s]
[INFO] wflow-plugin-base .................................. SUCCESS [ 0.014 s]
[INFO] wflow-plugin-archetype ............................. SUCCESS [ 0.082 s]
[INFO] wflow-directory .................................... SUCCESS [ 0.004 s]
[INFO] wflow-wfengine ..................................... SUCCESS [ 0.014 s]
[INFO] wflow-core ......................................... SUCCESS [ 0.010 s]
[INFO] wflow-consoleweb ................................... SUCCESS [ 0.051 s]
[INFO] wflow-designer ..................................... SUCCESS [ 0.004 s]
[INFO] wflow-designerweb .................................. SUCCESS [ 0.008 s]
[INFO] wflow-app .......................................... SUCCESS [ 0.220 s]
[INFO] BUILD SUCCESS
[INFO] Total time: 1.089 s
[INFO] Finished at: 2019-03-04T17:22:11-08:00
[INFO] Final Memory: 8M/21M
parallels@parallels-Parallels-Virtual-Platform:~/joget$ java -version
openjdk version "10.0.2" 2018-07-17
OpenJDK Runtime Environment (build 10.0.2+13-Ubuntu-1ubuntu0.18.04.4)
OpenJDK 64-Bit Server VM (build 10.0.2+13-Ubuntu-1ubuntu0.18.04.4, mixed mode)
parallels@parallels-Parallels-Virtual-Platform:~/joget$ mvn -version
Apache Maven 3.5.2
Maven home: /usr/share/maven
Java version: 10.0.2, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-11-openjdk-amd64
Default locale: en_US, platform encoding: UTF-8
OS name: "linux", version: "4.15.0-34-generic", arch: "amd64", family: "unix"
parallels@parallels-Parallels-Virtual-Platform:~/joget$ sudo find ./ -name '*war*'
parallels@parallels-Parallels-Virtual-Platform:~/joget/jw-community$ ll wflow-consoleweb/
total 28
drwxr-xr-x 3 root root 4096 Mar 5 10:15 ./
drwxr-xr-x 15 root root 4096 Mar 5 10:15 ../
-rwxr-xr-x 1 root root 14193 Mar 5 10:15 pom.xml*
drwxr-xr-x 3 root root 4096 Mar 5 10:15 src/
Hi, in a Maven project the output will be in the "target" directory.
[INFO]
Apache Maven 3.5.2
total 28
