Hi, if the hash variable is in your email content then it should work. If I were to guess, could be because there isn't any default record ID for the hash variable to determine which row to return. You can try passing in the record ID eg #form. tableName . fieldId [recordId]# as mentioned in Hash Variable#FormDataHashVariable
I am sending email using email tool while submitting form. I used the hash variable in system path
Ex:C:\Joget-v6\wflow\app_formuploads\PO_Details_pdf\#form.po_creation.id#.pdf
but the hash variable not replaced. So attachment fails.Is hash variable applicable in system path.
Kindly reply please
