Hello, i am still getting the same bug. Do you have some news on your side ?
I was able to test the following date picker display format without errors:
I attach the test app for your benefit. The date display format needs to confirm to the jQuery Datepicker Widget at http://api.jqueryui.com/datepicker/ .
APP_42041641_date_picker_month.jwa
Thank you.
Hi. I am still getting the same bug with this test app. I have edited my post with a screenshot.
Hello, I would like to report a bug.
When a Date Picker component is set to display month names rather than numbers (e.g. "display format" set to "dd-M-y" -- or in general using "M" instead of "m" for the month) then validation always fails with the message "Invalid date format".
This has been observed:
Version: Joget Workflow Enterprise 6.0.9 - build 78dd15d
Edit: example of the bug
