Greetings Team!
we would like to upload a file and upon loading it or saving the record, change the filename to add the value of  a field within the form. is that even possible?
      Hi, the file handling appears to be in the FileUpload element, so if you need custom behavior you could customize your own plugin based on its code https://github.com/jogetworkflow/jw-community/blob/6.0-SNAPSHOT/wflow-core/src/main/java/org/joget/apps/form/lib/FileUpload.java
