Hello,
      Please suggest me for use request parameter hash variable for calendar menu.
      I try to test pass URL with parameter but it not working and I check value is blank for query statement
      but it value appear in HTML tag.
      My Steps :
      1. URL → http://..../_/calendarSales?oid=859
      2. Properties → SQL SELECT Query ->
                           select id, c_date, c_time, c_subjet
                          from xxxxx
                          where c_OwnerId = '#requestParam.oid#'
Best Regards,
Aorka.
      There are no parameters when calling the calendar menu, so the #requestParam.oid# will be blank.
      Maybe you meant to use "...where c_OwnerId = '#currentUser.username#' "
      See Hash Variable .
