I am currently trying INSERT a row into a table using Database Update Tool and it isn't working for me. Please see my insert statement below......
INSERT INTO app_fd_j_inv_master
    c_CategoryId, c_Description, c_LocationId, c_UnitMeasurement,
    c_QuantityBalance, c_AverageCost, c_TotalValue, c_Enteredby
SELECT
    c_CategoryList, c_Item, c_TransLocationTo, null,
    c_QuantityToTrans, 0, 0, #currentUser.firstName# #currentUser.lasstName#
FROM app_fd_j_inv_transfer
Thank for you help in advance
      Hi Briant Fletcher
      Attached is a sample app using the Database Update Tool to insert a record in the process tool but I could not replicate your issue.
      Kindly try this app and you may modify it to be as close to your current app, to try to repeat the error you are experiencing. Then attach your app here for the community to view/check. Thank you.
      APP_68354413_process_database_update_tool.jwa
      1. Briant Fletcher
        Hi Matthew King,
        I have looked at app and imported it. It works fine. I looked at my app and made changes to it to mirror yours and my INSERT still isn't working.
        In my app I'm updating one record while inserting another. I have separated the processes for updating and one for inserting. The Update works, however, the INSERT still is not working.
        I have attached my app here, for you to look at.
        APP_jinventory-3-20191017132107.jwa
        Thank you
      2. Matthew King
        Hi Briant Fletcher
        I checked your INSERT query and there are some errors in your SQL.
        For example:
        • There is no field called "c_TransLocationTo" in your database, I think you meant to type "c_TranLocationTo".
        • In addition, there is no field called "c_modifiedby", it is "modifiedBy" (smile).
        As I was running the Joget v6 on premise edition (Windows), after importing your app, I could use a WIndows database utility SQLyog to test the SQL script's validity. SQLyog will immediately show you the SQL syntax errors when you try to execute the SQL script. BTW the on premise edition of Joget will also present you with a joget.log which is useful for troubleshoot your app. MySQL has a similar Workbench utility for database management.
        Below is the full list of columns in your database for the table app_fd_j_inv_transfer for your reference:
        CREATE TABLE `app_fd_j_inv_transfer` (
        `id` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
        `dateCreated` datetime DEFAULT NULL,
        `dateModified` datetime DEFAULT NULL,
        `createdBy` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
        `createdByName` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
        `modifiedBy` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
        `modifiedByName` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_TranLocationTo` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_Item` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_Unit_ID` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_CategoryList` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_ItemTrans` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_TransferAction` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_TransLocationForm` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_TransferDate` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        `c_QuantityToTrans` longtext COLLATE utf8_unicode_ci DEFAULT NULL,
        PRIMARY KEY (`id`)
        ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci
        Hope this helps.
        Thank you.
      3. Briant Fletcher
        It does and I understand totally, but I didn't know I can link the cloud version to workbench.
        I made the changes and I now it's working. Thank you
        One other thing how do I the get the id to insert as the format that is in the Table already?
        Thank ou
      4. Briant Fletcher
        How do I get it see the columns in the table in the database?
      I think i figure out why. You insert data to a form data table. The id column of a form data table cannot be NULL value. You may find the error shown in the log file. Try with the following and see.
        id,
        c_CategoryId,
        c_Description,
        c_LocationId,
        c_QuantityBalance
      SELECT
        uuid(),
        c_CategoryList,
        c_Item,
        c_TransLocationTo,
        c_QuantityToTrans
      1. Briant Fletcher
        Just tried this and No Luck. Still not inserting into the table.
      I think the problem is with the way you use Hash Variable. The 2 hash variable you used will become 2 unknown field to the query. You can try with the following by adding single quote to it.
      SELECT
          c_QuantityToTrans, 0, 0, '#currentUser.firstName# #currentUser.lasstName#'
      1. Briant Fletcher
        Yes, I had thought about that and actually took it out.
          c_CategoryId,
          c_Description,
          c_LocationId,
          c_QuantityBalance
        SELECT
          c_CategoryList,
          c_Item,
          c_TransLocationTo,
          c_QuantityToTrans
        And it still isn't working. I'm currently stumped.
        Question....
        If I have a Database Update Tool plugin that does an update in the same process would that affect it? The update is done before.
        Should break it apart in 2 different processes instead?
      2. Briant Fletcher
        Ok, just tried separating the 2 and the INSERT still doesn't work...
