Greetings - I am trying to use a current text field on a form as a parameter in the SQL statement to populate a SelectBox. example:
Select Name, Name from TableName Where Condiition = "TextfieldName"
How is the textfield referenced within the SQL query? the form would not be saved yet.
thanks
tony
      Hi Anthony
      These links in Joget Knowledge Base might help:
        so it works with the form binder and same process  as above. I guess its a Jdbc limitation.
        Cheers - Tony
          Ok - so I structure the sql in the selectbox as such:
          SELECT c_Balance, c_Balance
          FROM aimsportal.app_fd_PurchaseOrder
          WHERE c_PurchaseOrderNumber = ?
          and in the next screen I setup a textfield as the Field ID to control available options based on Grouping.
          however it doesnt seem to work? is it due to the community edition we are testing on?
