I have defined the following Custome HTML inside a joget form:-
<script language="JavaScript">
   function test () {
    $.ajax({
        url: "http://localhost:8080/jw/web/json/workflow/package/list",
        type: "GET",
        cache: false,
dataType : "JSONP",
        success: function (result) {
            $('#products').empty();
            $('#title').text("All Processes");
            $.each(result.data, function (key, val) {
                var str = val.packageName;
                $('<li/>', { text: str })
                    .appendTo($('#products'));
    </script>
    <form name="myForm">
      <input type="button"
             value="Display alert box"
             name="button1"
             onClick="alert('You clicked the first button.')"><br>
             value="Call on button 1"
             name="button2"
             onClick="test()">
<h1 id ="title"></h1>
<ul id="products">
</ul>
    </form>
<h1></h1>
<ul id="products">
</ul>
but when i tried to complete the task through the joget form i got the following exception, baring in mind that if i remove the custom html then i will be able to complete the task without any problem.:-
javax.transaction.xa.XAException: org.apache.commons.dbcp.managed.LocalXAConnec:
 resource no longer available - recovery might be at risk!
        at com.atomikos.datasource.xa.XAResourceTransaction.throwXAExceptionForU
navailableResource(XAResourceTransaction.java:311)
        at com.atomikos.datasource.xa.XAResourceTransaction.testOrRefreshXAResou
rceFor2PC(XAResourceTransaction.java:283)
        at com.atomikos.datasource.xa.XAResourceTransaction.commit(XAResourceTra
nsaction.java:779)
        at com.atomikos.icatch.imp.CommitMessage.send(CommitMessage.java:73)
        at com.atomikos.icatch.imp.PropagationMessage.submit(PropagationMessage.
java:111)
        at com.atomikos.icatch.imp.Propagator$PropagatorThread.run(Propagator.ja
va:87)
        at com.atomikos.icatch.imp.Propagator.submitPropagationMessage(Propagato
r.java:66)
        at com.atomikos.icatch.imp.HeurHazardStateHandler.onTimeout(HeurHazardSt
ateHandler.java:120)
        at com.atomikos.icatch.imp.CoordinatorImp.alarm(CoordinatorImp.java:1105
        at com.atomikos.timing.PooledAlarmTimer.notifyListeners(PooledAlarmTimer
.java:112)
        at com.atomikos.timing.PooledAlarmTimer.run(PooledAlarmTimer.java:99)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExec
utor.java:885)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor
.java:907)
        at java.lang.Thread.run(Thread.java:619)
WARN  04 Nov 2012 10:33:22 atomikos  - Unexpected error in commit
com.atomikos.icatch.SysException: XA resource 'org.apache.commons.dbcp.managed.L
ocalXAConnec': commit for XID '3139322E3136382E312E39302E746D3031333737303030343
4:6F72672E6170616368652E636F6D6D6F6E732E646263702E6D616E616765642E4C6F63616C5841
436F6E6E656331333132' raised -7: the XA resource has become unavailable
nsaction.java:824)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
WARN  04 Nov 2012 10:33:22 atomikos  - Local heuristic termination of coordinato
r 192.168.1.90.tm0137700044 with state HEUR_HAZARD
WARN  04 Nov 2012 10:33:22 atomikos  - org.apache.commons.dbcp.managed.LocalXACo
nnec: resource no longer available - recovery might be at risk!
WARN  04 Nov 2012 10:33:22 atomikos  - XA resource 'org.apache.commons.dbcp.mana
ged.LocalXAConnec': commit for XID '3139322E3136382E312E39302E746D30313337373030
303434:6F72672E6170616368652E636F6D6D6F6E732E646263702E6D616E616765642E4C6F63616
C5841436F6E6E656331333132' raised -7: the XA resource has become unavailable
nsaction.java:779)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
nsaction.java:824)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
WARN  04 Nov 2012 10:33:32 atomikos  - org.apache.commons.dbcp.managed.LocalXACo
WARN  04 Nov 2012 10:33:32 atomikos  - XA resource 'org.apache.commons.dbcp.mana
nsaction.java:779)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
WARN  04 Nov 2012 10:33:32 atomikos  - Unexpected error in commit
nsaction.java:824)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
WARN  04 Nov 2012 10:33:42 atomikos  - org.apache.commons.dbcp.managed.LocalXACo
WARN  04 Nov 2012 10:33:42 atomikos  - XA resource 'org.apache.commons.dbcp.mana
nsaction.java:779)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
WARN  04 Nov 2012 10:33:42 atomikos  - Unexpected error in commit
nsaction.java:824)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
WARN  04 Nov 2012 10:33:52 atomikos  - org.apache.commons.dbcp.managed.LocalXACo
WARN  04 Nov 2012 10:33:52 atomikos  - XA resource 'org.apache.commons.dbcp.mana
nsaction.java:779)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
WARN  04 Nov 2012 10:33:52 atomikos  - Unexpected error in commit
nsaction.java:824)
java:111)
va:87)
r.java:66)
.java:112)
utor.java:885)
.java:907)
so can anyone explain what is wrong ?
    Your problem and the log you attached does not seem to be related. For the error in your log, please see this link http://dev.joget.org/community/display/FORUM/Error+.+No+properties+path+set+-+looking+for+transactions.properties+in+classpath...?focusedCommentId=8716878#comment-8716878
