I can't connect Joget v3 with MS SQL Server 2005 and SQL Express 2008.  I need to insert in a MSSQL database the form's information.  In the desing I create a tool that use Database Update Plugin with the next configuration:
- Database type: MS SQL Server
- Target DB URL: jdbc:microsoft:sqlserver://localhost:1433;database=DatabaseName;
- Username: sa
- Password: Password sa's user
- Query: Insert query to the database's table.
When the tool is executed I have the next error: "Error executing plugin org.apache.commons.dbcp.SQLNestedException: Cannot load JDBC driver class 'com.microsoft.jdbc.sqlserver.SQLServerDriver'".
I try with a lot of solutions in other forums, but I can´t obtain a right answer.  I try the same workflow in Joget v2 and this executed correctly.
Somebody have an aswer for this problem?
Thank you!!!
  1. Hi Victoria,
    Looks like you are missing the required driver class from the Tomcat instance.
    Please have a look at the link on the right of this text. Cannot load JDBC driver class
