I need to add extra links, menu options and functionalities to the current Joget web console; so I have the following two questions:-
1. How can i modify the current web console such as modifying the main menu, add new links and add new functionalities.?.
2. Is it possible to develop a new web console using for example asp.net or PHP, and if the answer is yes then is it a good practice to do so ? or i might fall into problems especially when i need to upgrade the Joget workflow to a new version ?
Thank in advance for any help.
Best Regards.
